  3. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd , 31 May, 2025
Gurux DLMS for Android
public GXSerial(Context context) {
if (context == null) {
throw new IllegalArgumentException("context");
mContext = context;
GXUsbReceiver mUsbReceiver = new GXUsbReceiver(this);
String name = "gurux.serial";
IntentFilter filter2 = new IntentFilter(name);
filter2.addAction(UsbManager.ACTION_USB_DEVICE_ATTACHED);
filter2.addAction(UsbManager.ACTION_USB_DEVICE_DETACHED);
mContext.registerReceiver(mUsbReceiver, filter2, Context.RECEIVER_NOT_EXPORTED);
mSyncBase = new GXSynchronousMediaBase(200);
setConfigurableSettings(AvailableMediaSettings.ALL.getValue());
this supports only android 8 and above
it is not supporting for android 7 devices i am getting
FATAL EXCEPTION: main
Process: com.iiits.TrmSbd.sit, PID: 6896
java.lang.NoSuchMethodError: No virtual method registerReceiver(Landroid/content/BroadcastReceiver;Landroid/content/IntentFilter;I)Landroid/content/Intent; in class Landroid/content/Context; or its super classes (declaration of 'android.content.Context' appears in /system/framework/framework.jar)
at gurux.serial.GXSerial.<init>(GXSerial.java:216)
i am having the option of
if (Build.VERSION.SDK_INT >= Build.VERSION_CODES.TIRAMISU) {
context.registerReceiver(mUsbReceiver, filter, Context.RECEIVER_NOT_EXPORTED);
} else {
context.registerReceiver(mUsbReceiver, filter);
this but
GXSerial is read only class i want this to support from android 7
1 year 5 months ago
Hi, Google ended support for…
Google ended support for Android 7 in August 2019. If you want to support Android 7 devices, you can modify the source code to meet your needs.
It's recommended that you update the version seven to newer versions.
atuldd
1 year 5 months ago
to modify in the code…
to modify in the code GXserial is read only class
which is where i am getting exception
i have shared you
which lies inside GXserial
getting this
exception
1 year 5 months ago
Hi, This Tiramisu check is…
This Tiramisu check is already in version 2.0.12. What version are you using?
atuldd
1 year 5 months ago
2.0.15 here i am getting the…
2.0.15
here i am getting the issue which is not supporting for android 7
i have to make
this changes for supporting android 7
which i could not able to do
please provide the solution for android 7
1 year 5 months ago
Hi, Google is no longer…
Google is no longer supporting Android 7, and we no longer have any Android 7 devices left.
