  3. Using General-ciphering Messages
Using general-ciphering messages
By sgbubble , 1 April, 2025
I want to do a small script to test general-ciphering messages using identified key, wrapped key and agreed key. I'm using the python library as a DLMS client.
Can you provide an example on how to configure it?
Thank you,
Sara
sgbubble
1 year 7 months ago
I'm using the Python library
1 year 7 months ago
Hi, The general-ciphering…
The general-ciphering use system title, block cipher and authentication keys to cipher the data. Check the -B -A -T arguments from the client example.
sgbubble
1 year 7 months ago
Hi, With those variables I…
With those variables I can do a general-glo-ciphering request, but I want to generate a general-ciphering one. Is it possible with the latest version of the library?
Thank you
1 year 7 months ago
Hi, You need to set the…
You need to set the general protection conformanse flag.
https://www.gurux.fi/Gurux.DLMS.Conformance#GeneralProtection
sgbubble
1 year 6 months ago
When General protection flag…
When General protection flag is active both general-global-ciphering and general-ciphering can be used, can't they?
How can I specify to use the later?
Thank you
