  2. High Authentication Problem
By utkubarisgumus , 28 March, 2025
Gurux DLMS for ANSI C
Hello, I downloaded the project in the path "https://github.com/Gurux/GuruxDLMS.c/blob/master/Keil/NUCLEO-L433xx/Gur…; to my computer. I uploaded it to my own meter. I managed to connect to the meter and communicate with it using Gurux GXDLMSDirector. However, when I set the Authentication level to High and enter the password as "Gurux" as you indicated, I get the error "Access Error : Device reports Read-Write denied". I don't understand what else I need to do. Can you help me?
1 year 2 months ago
Hi, This example doesn't…
This example doesn't implement high authentication. You need to add it.
Check this example:
https://github.com/Gurux/GuruxDLMS.c/blob/9b61800b83df8b2a804e54d9d9be7…
utkubarisgumus
1 year 2 months ago
Hi Kurumi, First of all, i…
Hi Kurumi,
First of all, i compiled the server code in keil environment and uploaded it to my meter. i added high authentication section to the code as you mentioned before. but i get "access error: device reports read-write denied" error every time whether i enter the password correctly or incorrectly. do you have a document explaining what i need to do? or can you direct me?
1 year 2 months ago
Hi, Check that you have…
Check that you have added the new association view (associationHigh) to ALL_OBJECTS. https://github.com/Gurux/GuruxDLMS.c/blob/a97852034918b246c16f445ff2cb2…
Then check that you call addAssociationHigh.
GXDLMSDirector must use the same client address that you have defined for this association. In this example it's 0x12.
utkubarisgumus
1 year 1 month ago
Hi Kurumi, "https://github…
Hi Kurumi,
"https://github.com/Gurux/GuruxDLMS.c/blob/9b61800b83df8b2a804e54d9d9be7…; I created a server from scratch according to the example you gave in this link and ran it. I added encryption to this code as you mentioned. I am having the following problem. When I set the authentication to none, it connects to the meter and gets the object list in the meter. However, when I set the authentication to high and enter the password, I connect to the meter, but I get the error "GetObject failed. Unacceptable frame" when reading the object list. When I debug the server code, the problem I caught appears as "DLMS_ERROR_CODE_OUTOFMEMORY". I could not overcome this problem. Can you help me? As I asked before, do you have a clearer and more precise document for creating a meter? I am running the code, but I could not find any initial settings or similar explanation.
1 year 1 month ago
Hi, The high authentication…
The high authentication is already in the server example. Check that you are using the same client address. The example is using client address 0x12.
Check this:
https://gurux.fi/Gurux.DLMS.Server
