  2. SL7000 AC VOLTAGE L1-L2
By jvergara2 , 8 March, 2025
I'm looking for the OBIS codes to read AC VOLTAGE L1-L2, AC VOLTAGE L2-L3, and AC VOLTAGE L3-L1 from my SL7000. Do you know the OBIS codes I need?
I have these for other measurements and would also like to confirm if they are correct:
AC CURRENT L1 = 1.1.31.7.0.255 Unit: A
AC CURRENT L2 = 1.1.51.7.0.255 Unit: A
AC CURRENT L3 = 1.1.71.7.0.255 Unit: A
AC POWER = 1.1.2.7.0.255 Unit: kW
AC VOLTAGE L1 = 1.1.32.7.0.255 Unit: V
AC VOLTAGE L2 = 1.1.52.7.0.255 Unit: V
AC VOLTAGE L3 = 1.1.72.7.0.255 Unit: V
AC VOLTAGE L1-L2 = ?????? I need this in V
AC VOLTAGE L2-L3 = ?????? I need this in V
AC VOLTAGE L3-L1 = ?????? I need this in V
FREQUENCY = 1.1.14.7.0.255 Unit: Hz
POWER FACTOR = 1.1.13.7.0.255
REACTIVE POWER = 1.1.3.7.0.255 Unit: kVAr
TOTAL AC ENERGY PRODUCED = 1.1.2.8.0.255 Unit: kWh
TOTAL AC ENERGY CONSUMED = 1.1.1.8.0.255 Unit: kWh
Do you have the correct OBIS codes for L1-L2, L2-L3, and L3-L1 voltages?
1 year 3 months ago
Hi, I can't remember what…
I can't remember what OBIS codes SL7000 is using. You can see all the OBIS codes if you establish the connection to the meter with GXDLMSDirector.
Select Actaris as a manufacturer in GXDLMSDirector.
jvergara2
1 year 3 months ago
Thank you so much. I'm going…
Thank you so much. I'm going to try and will get back you.
