  3. Gurux.dlms.GXDLMSException: Invalid Exception.
gurux.dlms.GXDLMSException: Invalid Exception.
By Tsveten.Kavrakov , 20 February, 2025
when i call client.parseUAResponse(response); with response "7EA0230300023E2F73D577818014050200F8060200F807040000000108040000000158717E" it rises Invalid exception, but I copied this response from factory application log and this i valid. What is wrong ?
1 year 8 months ago
Hi, What programming…
What programming language are you using?
Tsveten.Kavrakov
1 year 8 months ago
Hi I'm using Java
I'm using Java
1 year 8 months ago
Hi, Did you convert hex log…
Did you convert hex log hex data data to bytearray?
I believe that one of your settings is different that what the meter uses.
With GXDLMSTranslator you can convert data to XML string like this:
GXDLMSTranslator t = new GXDLMSTranslator();
GXByteBuffer bb = new GXByteBuffer();
bb.setHexString("7EA0230300023E2F73D577818014050200F8060200F807040000000108040000000158717E");
System.out.println(t.messageToXml(bb));
