  3. Invalid Count In Parsing
Invalid Count in parsing
By Bhaumik , 7 February, 2025
Dear Mikko,
I am using an Indian standard meter, and while parsing push data, I encountered an "Invalid Count" exception in the gXDLMSSecureClient.GetData(data, replyData, notify) function.
The same function works correctly with push data from other meters.
Could you please suggest what might be causing this issue?
1 year 9 months ago
Hi, I believe that the meter…
I believe that the meter is sending invalid data. Ask if there is a firmware update available for the meter. here I can verify this from the bytes if you add the hex trace.
