  3. How To Fetch Obis Code of Instantaneous Profile
How to fetch Obis code of Instantaneous Profile
By sirishalv72@gm… , 7 February, 2025
Gurux.Net
I am trying to fetch the OBIS code (Logical Name) of the Instantaneous Profile using the following code. However, every time I execute it, I only get the values instead of the OBIS code. I have also tried using attributes 1 and 2, but I still receive only the values.
Could you please help me retrieve the OBIS code (Logical Name) correctly?
Here is my code
GXDLMSProfileGeneric profileGeneric = new GXDLMSProfileGeneric(obj.LogicalName);
// Define list of captured objects
var capturedObjectsList = new List<GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>>();
// Define capture object
var c = new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>();
GXDLMSData gxobject = new GXDLMSData();
gxobject.LogicalName = obj.LogicalName;
GXDLMSCaptureObject captureObject = new GXDLMSCaptureObject();
captureObject.AttributeIndex = 3;
captureObject.DataIndex = 0;
c.Key = gxobject;
c.Value = captureObject;
// Add the capture object to the list
capturedObjectsList.Add(c);
// Assign the list to the profileGeneric object
profileGeneric.CaptureObjects = capturedObjectsList;
var a = Client.Settings.Objects.GetObjects(ObjectType.ProfileGeneric);
// Start reading
res = Client.ReadRowsByRange(profileGeneric, DateTime.Now.AddDays(-2), DateTime.Now.AddDays(-1), capturedObjectsList);
conn.ReadDataBlock(res, reply);
Every time I run this, I only receive the values, but I need to fetch the OBIS code (Logical Name) instead.
Thanks!
1 year 8 months ago
Hi, If you want to know the…
If you want to know the logical name for profile generic you need to read attribute index #1 like this:
res = Client.Read(profileGeneric, 1);
