  3. DLMS US Connection
DLMS US Connection
By sirishalv72@gm… , 15 November, 2024
I've doubt regarding DLMS US Connection to disconnect the meter.
For connection I changed the Authentication level High and trying to set Frame Counter LN
How to set it.
Please kindly help with this
2 years ago
Hi, You need also change the…
You need also change the client address and set correct block and authentication keys.
Then you need to read correct invocation couter from the meter.
I suggest that you read the meter with GXDLMSDirector. It will show the correct command line arguments that you need to set.
