  3. Decoding a Ciphered Frame
Decoding a Ciphered frame
By dsoler , 12 November, 2024
Hi there!
I-m trying to use the GXDLMSTranslator class to decode a ciphered frame.
This is what I did but the output keeps the chipered data.
_gXDLMSTranslator = new Gurux.DLMS.GXDLMSTranslator(TranslatorOutputType.SimpleXml);
_gXDLMSTranslator.Hex = false;
_gXDLMSTranslator.Security = Security.AuthenticationEncryption;
_gXDLMSTranslator.SecuritySuite = Gurux.DLMS.Objects.Enums.SecuritySuite.Suite0;
_gXDLMSTranslator.BlockCipherKey = GXCommon.HexToBytes("<bytes of the key>");
_gXDLMSTranslator.AuthenticationKey = GXCommon.HexToBytes("<bytes of the key>");
_gXDLMSTranslator.InvocationCounter = 0;
string xml = _gXDLMSTranslator.MessageToXml(data);
After this the string xml has the ciphered service tag with a encoded value.
how could I decode it? is there any function or setup missing? thanks in advance!
2 years ago
Hi, You can see the decoded…
You can see the decoded value in comments if you set comments true like this:
_gXDLMSTranslator.setComments(true);
