  3. Old Data Doesn't Disappear On Second Request In DLMSDirector With .NET Gurux DLMServer
Old data doesn't disappear on Second Request in DLMSDirector with .NET Gurux DLMServer
By liemoon , 1 November, 2024
I’m building a DLMServer in .NET and testing it with DLMSDirector. On the first read of a profile generic, two data entries appear as expected. However, on the second request, the old data doesn’t clear, resulting in four entries showing up in DLMSDirector. In the preread section of DLMServer, I’ve tried clearing the buffer before adding new data, but the issue persists. How can I ensure the old data is cleared properly before each new read request?
Here's my code to handle the profile generic:
[LogicalName("1.97.99.98.1.255")]
public class TestController(ILogger<TestController> logger) : DLMSControllerBase
private static GXDLMSProfileGeneric pf = new();
public override GXDLMSObject gxObject => new GXDLMSProfileGeneric
LogicalName = logicalName,
CaptureObjects = [
new(new GXDLMSClock(),new GXDLMSCaptureObject(2,0)),
new(new GXDLMSRegister("0.0.96.6.3.255"),new GXDLMSCaptureObject(2,0)),
private static DateTime now = DateTime.Now;
public override void ReadHandler(ValueEventArgs e)
try
if (e.Index == 2)
var obj = (GXDLMSProfileGeneric)e.Target;
obj.Buffer.Clear();
obj.Buffer.AddRange([[now.AddDays(-2), 123], [now, 1234]]);
catch (Exception ex)
logger.LogError(ex.Message);
2 years ago
Hi, I get the latest version…
Hi, I got the latest version from GitHub and it worked without problems. Check your code.
protected override void PreRead(ValueEventArgs[] args)
    foreach (ValueEventArgs e in args)
        //Framework will handle profile generic automatically.
        if (e.Target is GXDLMSProfileGeneric)
            if (e.Index == 2)
        	    //Client reads buffer.
        	    GXDLMSProfileGeneric p = (GXDLMSProfileGeneric)e.Target;
        	    obj.Buffer.Clear();
        	    obj.Buffer.Add(new object[] { now.AddDays(-2), 123 });
        	    obj.Buffer.Add(new object[] { now, 1234 });
