  3. DLMS Server Implementation: TCP/IP
By girija , 28 September, 2024
Hello Sir,
We want to implement TCP/IP communication profile at server (Meter) side. In C-library, by defining IP6_SETUP the error shows several missing files regarding socket, win/linux. This errors are limitless even after adding the files. My question is, does the window/linux-library for TCP/IP needed while implementing on the server (Meter) side?
Guide me if I am making mistake in defining macros in gxignore.h file.
Note: Our application in non-OS based.
Thank you.
Girija
