  3. Disconnect Mode Error While Using HDLC To Read
Disconnect Mode Error while using HDLC to read
By Rahuls , 29 August, 2024
Gurux.Net
Hey kurumi, getting this error message when trying to read from using hdlc cable
Gurux.DLMS.GXDLMSException: Disconnect mode.\r\n at MeterBaseSystem.DLMSHelper.ReadDLMSPacket(Byte[] data, GXReplyData reply)
works correclty with tcp mode, but getting error in HDLC mode
serial.PortName = GXSerial.GetPortNames()[0];
serial.BaudRate = 9600;
serial.DataBits = 8;
serial.Parity = System.IO.Ports.Parity.None;
serial.StopBits = System.IO.Ports.StopBits.One;
thanks in advance
2 years 2 months ago
Hi, What kind of error are…
What kind of error are you receiving? Can you add when hex trace what the meter is responding?
Rahuls
Send 11:39:20 AM 7E A0 07 03…
Send 11:39:20 AM 7E A0 07 03 21 93 0F 01 7E
Recv 11:39:20 AM 7E A0 20 21 03 73 73 98 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
Send 11:39:20 AM 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 88 55 7E
Recv 11:39:20 AM 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 03 40 00 07 D1 F0 7E
Send 11:39:20 AM 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 03 FF 02 00 B0 AA 7E
Recv 11:39:20 AM 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 15 51 5F 7E
Send 11:39:20 AM 7E A0 07 03 21 53 03 C7 7E
----------------------------------------New Read-------------------------------------------
Send 11:39:21 AM 7E A0 7C 03 61 10 AA 6B E6 E6 00 60 6E A1 09 06
07 60 85 74 05 08 01 03 A6 0A 04 08 4F 41 4B 30 30 30 30 31 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 37 2C 5D 25 09 15 50 75 4A 27 4F 2E 2D 71 42 30 BE 34 04 32 21 30 30 00 00 00 16 CC 4B 43 CF 4A E5 32 D4 25 E4 E2 9A CB 51 DE 4E C6 1C 29 0D 22 76 18 D7 8A 57 7E 24 E2 87 96 8B 0D DC 7E 82 F7 E7 42 25 D7 9A 9C 54 20 7E
Recv 11:39:21 AM 7E A0 07 61 03 1F 1D EF 7E\n"
Hi, You must send SNRM and…
You must send SNRM and handle received UA before establishing the new ciphered connection.
Rahuls
Yes I am doing that while…
Yes I am doing that
while reading innvocation counter, then disconnecting it.
Then new AArq request for profile read.
Hi, OK. That was removed…
OK. That was removed from the log you posted.
Try to connect with the client example. When you select the device, you can see the correct command line parameters in GXDLMSDirector.
Rahuls
Hi mikko, a little update i…
i tried running .net version of gurux console app but was getting dependency issue.
I tried in my app, I am able to read invocation counter using PC mode and able to set it, but i get Disconnect Mode error in making aarqrequest while reading anything in Us mode.
this.settings.client.UseLogicalNameReferencing = true;
this.settings.client.InterfaceType = read.mediaType == MediaType.TCP ? InterfaceType.WRAPPER : InterfaceType.HDLC;
this.settings.client.ClientAddress = read.ClientId;
this.settings.client.ServerAddress = read.ServerId;
this.settings.client.Password = ASCIIEncoding.ASCII.GetBytes(read.Password);
this.settings.client.Authentication = Authentication.High;
this.settings.client.Ciphering.Security = Security.AuthenticationEncryption;
this.settings.client.Ciphering.SystemTitle = GXCommon.HexToBytes(AsciiToHex(read.SystemTitle)); // assuming default
this.settings.client.Ciphering.SecuritySuite = Gurux.DLMS.Objects.Enums.SecuritySuite.Suite0;
this.settings.client.Ciphering.AuthenticationKey = GXCommon.HexToBytes(AsciiToHex(read.AuthenticationKey));
this.settings.client.Ciphering.BlockCipherKey = GXCommon.HexToBytes(AsciiToHex(read.BlockCipherKey));
this.settings.client.Ciphering.InvocationCounter = counter + 1;
if (!string.IsNullOrEmpty(read.DedicatedKey))
this.settings.client.Ciphering.DedicatedKey = GXCommon.HexToBytes(AsciiToHex(read.DedicatedKey));
this.settings.client.Standard = Standard.India; // changing default
this.settings.client.Plc.MacDestinationAddress = UInt16.Parse("0"); // dont know yet
this.settings.client.ServiceClass = ServiceClass.Confirmed;
InitializeMedia(read);
am i missing something?
and is intervaltimeout mandatory for hdlc?
thanks
Hi, HDLC don't use PDC. You…
HDLC don't use PDC. You can remove this line:
Try to wait for two seconds before establishing the connection again. Some meters require that.
Rahuls
Hey mikko, i added 2 sec…
Hey mikko, i added 2 sec delay, still same error
Hi, Try to connect with…
Try to connect with GXDLMSDirector. I believe it will help you to get the correct settings.
Rahuls
Yes its wokring ccorreclty…
Yes its wokring ccorreclty on GXdlms director, and same settinngs are working correctly for tcp through my code. Only thing i am changing is interface type and media object with GXSerial settings.
In that also its working correctly for getting innvocation counter using HDLC, only US mode connection and reading is giving me this error
Hi, Try with client example…
Try with client example.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E…
You can see the correct command line arguments in the GXDLMSDirector.
In your previous post, you told that you have dependency issue. You need to install Nuget from https://www.nuget.org/. It will install all missing libraries.
