  3. Configurator Level Password Encryption By AES-GCM-128
Configurator level password encryption by AES-GCM-128
By JavierDiaz , 26 August, 2024
Please tell me, is there a ready tool for password encryption using aes gcm 128?
I need to encrypt the new password with the current password and pass it to the association method 2.
Thanks!
2 years 2 months ago
Hi, The DLMS standard is…
The DLMS standard is very open for the high-level password update. Different manufacturers are using different ways to update it.
You can try with AES RFC3394 key-wrapping.
You can try to update the password with GXDLMSSecureClient.Encrypt method.
Send generated bytes to meter using GXDLMSAssociationLogicalName.UpdateSecret method.
JavierDiaz
Thanks for the answer! This…
This method returns the encrypted password as a 24 byte array, our device expects 16 bytes, how can this be done?
Hi, It seems that the…
It seems that the password is only encrypted and AES RFC3394 key-wrapping is not used. What programming language are you using?
JavierDiaz
Thanks for the answer! I use…
I use C#, the password is encrypted using aes-128.
