  3. Unable To Connect Electric Smart Meter.(aarq Request Failed)
Unable to connect electric smart meter.(aarq request failed)
By jayaram , 23 August, 2024
Gurux.Net
GXDLMSSecureClient sclient = new GXDLMSSecureClient();
GXNet gXNet = new GXNet(NetworkType.Tcp, "ip address", 4059);
sclient.UseLogicalNameReferencing = true;
// Is used HDLC or COSEM transport layers for IPv4 networks (IEC 62056-47)
sclient.InterfaceType = InterfaceType.WRAPPER;
sclient.ClientAddress = 32;
sclient.ServerAddress = 1;
sclient.Authentication = Authentication.Low;
sclient.Password = ASCIIEncoding.ASCII.GetBytes("123456");
sclient.Ciphering.SecuritySuite = SecuritySuite.Suite0;
sclient.Ciphering.Security = Security.AuthenticationEncryption;
sclient.Ciphering.SystemTitle = GXCommon.HexToBytes("7177657274797569");
sclient.Ciphering.BlockCipherKey = GXCommon.HexToBytes("62626262626262626262626262626262");
sclient.Ciphering.AuthenticationKey = GXCommon.HexToBytes("62626262626262626262626262626262");
sclient.Ciphering.Signing = Signing.None;
Media = gXNet as IGXMedia;
Media.Open();
byte[] data;
data = sclient.SNRMRequest();
if (data != null)
ReadDLMSPacket(data, reply);
sclient.ParseUAResponse(reply.Data);
//Generate AARQ request.
//Split requests to multiple packets if needed.
//If password is used all data might not fit to one packet.
foreach (byte[] it in sclient.AARQRequest())
Console.WriteLine("Send AARQ request-{0}", GXCommon.ToHex(it, true));
reply.Clear();
reply = ReadDLMSPacket(it, reply);
//Parse reply.
sclient.ParseAAREResponse(reply.Data);
Console.WriteLine("Conformance: " + sclient.NegotiatedConformance);
Console.WriteLine(sclient.ConnectionState);
byte[][] obj = sclient.Read("0.0.42.0.0.255", ObjectType.Data, 2);
/// Read Association View from the meter.
reply = new GXReplyData();
ReadDataBlock(obj, reply);
public static GXReplyData ReadDLMSPacket(byte[] data, GXReplyData reply)
if (data == null)
return reply;
object eop = (byte)0x7E;
//In network connection terminator is not used.
int pos = 0;
bool succeeded = false;
ReceiveParameters<byte[]> p = new ReceiveParameters<byte[]>()
AllData = true,
Eop = eop,
Count = 5,
WaitTime = 5000,
lock (Media.Synchronous)
while (!succeeded && pos != 3)
Media.Send(data, null);
succeeded = Media.Receive(p);
Console.WriteLine("Response-{0}", GXCommon.ToHex(p.Reply, true));
if (!succeeded)
//If Eop is not set read one byte at time.
if (p.Eop == null)
p.Count = 1;
//Try to read again...
if (++pos != 3)
System.Diagnostics.Debug.WriteLine("Data send failed. Try to resend " + pos.ToString() + "/3");
continue;
throw new Exception("Failed to receive reply from the device in given time.");
//Loop until whole COSEM packet is received.
while (!client.GetData(p.Reply, reply))
if (p.Eop == null)
p.Count = 1;
if (!Media.Receive(p))
if (pos != 3)
continue;
if (reply.Error != 0)
throw new GXDLMSException(reply.Error);
return reply;
2 years 3 months ago
Hi, Please, don't copy the…
Please, don't copy the example code. It doesn't say anything about the problem.
Are you getting any reply from the meter?
I believe that one of your settings is different than the meter expects.
Try to connect with GXDLMSDirector to get the correct settings.
jayaram
2 years 2 months ago
I am connection with wrapper…
I am connection with wrapper interface type but its not working and i tried with gxdlmsdirector it is working
Send AARQ request-00 01 00 20 00 01 00 55 60 53 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 08 80 06 31 32 33 34 35 36 BE 23 04 21 21 1F 30 00 00 00 02 B9 C9 87 9D 5B 75 7F 27 5C 00 73 25 83 4B 71 A9 03 13 C6 2F 58 AC 36 10 5F 48
Response-00 01 00 01 00 20 00 0C 4E 45 58 45 52 52 4F 52 4E 4F 2D 31
Hi, Can you add the first…
Can you add the first message that GXDLMSDirector sends? I can get the correct settings for you.
I believe that you are reading the Innovation counter with GXDLMSDirector and that is causing the issue.
jayaram
Hi, Issue is resolved.I set …
Issue is resolved.I set object eop = null instead of object eop = (byte)0x7E;
but now meter is responding properly for the first time after that if i try to connect second time its showing serviceerror Initiate error exception.
If i turned off the meter and turned on again then its working.what may be the reason?
Hi, At first, ask if there…
At first, ask if there is a firmware update available for the meter.
Did you call close after you have read the values from the meter?
jayaram
Hi, Yes,after reading values…
Yes,after reading values from meter i am sending releaserequest and disconnection request.
Hi, Don't send the release…
Don't send the release message. Send just disconnect. That might help with some meters. Can you connect with GXDLMSDirector?
jayaram
Hi, Tried by sending only…
Tried by sending only disconnection request but still not working.
ReadDLMSPacket(Client.DisconnectRequest(), reply);
RX:7E A0 07 03 41 53 56 A2 7E
TX:
but if i try with guruxdlmsdirector UI its working.
