  3. Uses of Gurux.DLMS.UI.Net
By Rajshri , 16 July, 2024
Gurux.Net
I am trying to use Gurux DLMS UI .Net but facing the issue with the below Gurux code. It's giving the error like property does not exist.
//Clear old view.
foreach (Control it in UIPanel.Controls)
it.Hide();
UIPanel.Controls.Clear();
//Select new COSEM object. In this example we select clock.
GXDLMSClock clock = new GXDLMSClock();
IGXDLMSView selectedView = views[clock];
selectedView.Target = clock;
GXDlmsUi.UpdateProperties(clock, selectedView);
//Add DLMS COSEM view to UI panel.
UIPanel.Controls.Add((Form)selectedView);
// Facing the issue with the below code, so request you to give the help on this part like how to use and why it's giving error //
Show UI.
((Form)selectedView).Show();
Rajshri
2 years 4 months ago
// Facing the issue with the…
Show UI.
Hi, Is the view included to…
Is the view included to views? Where are you exactly receiving this error and what is the error message?
Rajshri
GXDlmsUi.UpdateProperties…
giving error
UpdateProperties method not available in GXDlmsUi
2 years 3 months ago
Hi, There is no…
There is no UpdateProperties method in GXDlmsUi. Check your code.
