  3. Saving Access Rights In Associations (Python)
Saving access rights in associations (Python)
By alexcd , 5 June, 2024
Hello, I noticed that when saving an association, access rights are not saved correctly. When reading the access rights of an object, I get None or the rights do not match those written in AssociationLogicalName.
item = self.reader.client.objects.findByLN(ObjectType.NONE, "1.0.15.8.0.255")
print(item.getAccess(3))
#result Read/Write, but in AssociationLogicalName i see only Read
print(item.getAccess(2))
#result None but in AssociationLogicalName i see only Read
Maybe there is a different way to read these rights?
Thanks for answer.
2 years 4 months ago
Hi, Access rights are now…
Access rights are now serialized in version 1.0.155. Get the latest version.
alexcd
Hi Kurumi, in version 1.0…
Hi Kurumi, in version 1.0.155 I can't save the association file.
In 1.0.154 everything works as it should.
My counter also has non-standard producer object classes. ~When trying to recognize them, reading is interrupted and the file is not saved.
