  3. DLMS.c: Timeout When Reading ProfileGeneric
DLMS.c: Timeout when reading ProfileGeneric
By dvosp , 8 May, 2024
I'm having an issue reading ProfileGeneric from Landis & Gyr ZMG405. The meter currently has 931 entries in 1.0.99.1.0.255. I read one entry at a time. My read loop is:
for (int i = 1; i <= pg.entriesInUse; i++)
printf("Reading index %d", i);
int ret = com_readRowsByEntry(&settings, &pg, i, 1);
if (ret == DLMS_ERROR_CODE_OK)
else
printf(TAG, "Error...");
break;
It reads up to index 124, after that it times out.
in readDLMSPacket I print out the result of cl_getData.
ret = cl_getData(settings, &frameData, reply);
printf("\ncl_getData %d, %d\n", ret, reply->complete);
After the entry is read I also print out the columns.
Reading index 124
->7E A0 2F 00 02 50 C1 21 76 94 3B E6 E6 00 C0 01 C1 00 07 01 00 63 01 00 FF 02 01 02 02 04 06 00 00 00 7C 06 00 00 00 7C 12 00 01 12 00 00 89 0A 7E
<-7E A0 34 21 00 02 50 C1 96 4E 5E E6 E7 00 C4 01 C1 00 01 01 02 04 09 0C 07 E1 0B 1C 02 0D 1E 00 FF 80 00 01 06 00 80 00 12 05 00 00 00 00 05 00 00 00 00 73 E3 7E
cl_getData 0, 1
dlms Row 0
dlms col 0, 25, -32768, 13:30:00
dlms col 1, 6, 8388626
dlms col 2, 5, 0
dlms col 3, 5, 0
dlms Reading index 125
->7E A0 2F 00 02 50 C1 21 98 E4 35 E6 E6 00 C0 01 C1 00 07 01 00 63 01 00 FF 02 01 02 02 04 06 00 00 00 7D 06 00 00 00 7D 12 00 01 12 00 00 09 10 7E
7E A0 34 21 00 02 50 C1 B8 32 96 E6 E7 00 C4 01 C1 00 01 01 02 04 09 0C 07 E1 0B 1C 02 0E 00 00 FF 80 00 01 06 00 80 00 12 05 00 00 00 00 05 00 00 00 00 6F 7E
cl_getData 0, 0
reply->complete = 0 when requesting index 125. Because of this readDLMSPacket waits for another packet, but the meter does not send one, causing the communication to time out.
If i change the loop to
for (int i = 124; i <= 124; i++)
it works
for (int i = 124; i <= 125; i++)
it reads 124, but gets stuck at 125.
Any idea why this happens?
2 years 5 months ago
Hi, One CRC byte is missing…
One CRC byte is missing from the meter reply and packet is not complete.
The meter reply:
6F //Other CRC byte is missing.
7E
Check why this CRC byte is missing. It might be because the bad connection or there is an issue with UART/RS-232 reading.
dvosp
Hi Mikko, I can continuously…
I can continuously read record 124 successfully, while 125 fails every time but I'll check.
dvosp
Hi Mikko, I captured the raw…
I captured the raw serial data
TX: 7E A0 2F 00 02 76 DD 03 52 CE A8 E6 E6 00 C0 01 C1 00 07 01 00 63 01 00 FF 02 01 02 02 04 06 00 00 00 11 06 00 00 00 11 12 00 01 12 00 00 5C 76 7E
RX: 7E A0 4A 03 00 02 76 DD 54 D8 48 E6 E7 00 C4 01 C1 00 01 01 02 09 09 0C 07 E8 01 16 01 10 00 00 00 00 78 00 11 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 7E 4D 7E
As you can see the received frame ends with 7E 4D 7E.
The current int com_readSerialPort(unsigned char eop) from your examples will not handle this correctly.
The translator DLMSDirector seems to handle it OK.
Hi, I don't know if the…
I don't know if the problem is on the meter or the connection, but it's clear that the one byte is missing from the HDLC frame. You can try to repeat this with the GXDLMSDirector and if you face the same issue, check if there is a firmware update available for your meter.
dvosp
Hi Mikko, Found the issue. …
Found the issue. It was in my code, probably happened when I translated your examples to my platform. For the frame in question the first byte of the CRC is 0x7E (the same as the flag character). This was not handled properly.
Thanks for the trouble.
