  3. Read Values From DLMS
Read values from DLMS
By akshy , 18 April, 2024
Gurux.Net
Hi, I need to read values properly in correct format, right now I'm getting below hexa values: I need a correct values like current;=10.5 and voltage:240, how i can convert hexa to human values please suggest it is very urgent
Current:
TX: 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 EA A9 34 80 04 CB 82 40 40 D4 90 15 CB 44 7A 51 31 7B E4 0C 1D E1 AB 10 05 FF
RX: 00 01 00 01 00 30 00 1D CC 1B 30 00 00 01 E6 B8 E1 5C 66 0E AA 21 0E 0C 13 DB 28 B4 E9 B7 92 F8 CC DD 5E 0A EE
Voltage:
TX: 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 EB 90 F6 38 A8 EB 78 24 82 44 33 22 1A B4 01 E4 D7 B1 72 C5 3F 5F 7F 43 7F 19
RX: 00 01 00 01 00 30 00 1D CC 1B 30 00 00 01 E7 27 EF E3 42 D5 DC C8 09 0F B6 8C 38 E2 A6 38 14 86 E4 1B 72 F2 CF
2 years 7 months ago
Hi, I propose that you use…
I propose that you use Gurux open source libraries. DLMS is not an easy protocol and you can't just convert received binary data to ASCII.
https://github.com/gurux
akshy
Is there any way I need to…
Is there any way I need to convert into real values above which i mentioned those are hexa string i tired to convert into real values which is showing in dlms director...
Hi, Data is not a hex string…
Data is not a hex string. DLMS is a binary protocol. You need to parse the data, then handle it and show it as a string.
akshy
Please provide me sample if…
Please provide me sample if you have to convert the protocol into string.
Hi, It's not so simple…
It's not so simple. There are hundreds of pages in the standard. Your meter is also using a ciphered connection which makes it more difficult.
