  3. How To Read Values of OBIS In C# In Either XML or Some Format
How to Read values of OBIS in C# in either XML or some format
By Rahuls , 18 April, 2024
Gurux.Net
i need finally in dictionary form but i can convert from xml
reply = PublicClientAAREAARQ(reply);
reply.Clear();
byte[][] readBlockType = GetOBISReadBlock(obis);
ReadDataBlock(readBlockType, reply);
Client.ParseAAREResponse(reply.Data);
here i am getting invalid tag error is there any other way i can read it, also please help in context of reading GXDLMSObjectCollection,
thanks in advance
2 years 7 months ago
Hi, You need to establish…
You need to establish the connection to the meter before you can read anything. I propose that you check the client example. It does what you want to do.
https://github.com/Gurux/Gurux.DLMS.Net
