  3. Driver Landis Gyr AIP200 Optical Probe
Driver Landis Gyr AIP200 optical probe
Profile picture for user Electric_John
By Electric_John , 14 February, 2024
Hello! I search on entire internet and I didn't find driver for optical probe Landis Gyr AIP200, can anyone help me?
2 years 9 months ago
Hi, Don't try to search for…
Don't try to search for them on the internet. There are so many invalid drivers. You need to ask this from Landis+Gyr. We have the same problem with the Kamstrup optical probe for Windows 11 and they were very helpful and sent the drivers right away.
Electric_John
I try, maybe someone have…
I try, maybe someone have the driver/softwae for AIP200 and share with me, I pay for the driver if someone can help me. I have 4 optical probe (1 Emlog, 1 jm~tronik, 1 no name and this LG AIP200) and many smart meters Landis Gyr E550 but I can't read them.... With first 3 probes I can read data from a ZMG410, but I can't write data or acces Communication Unit in map120. When I try to read data from ZMG310, I received just errors. Now I try GXDLMSDirector but I can't connect to the smartmeter, I don't have option IEC to select. (sorry, my english is not very good)
Hi, Check the communication…
Check the communication log from "View", "Log" and "View Log". Is the meter replying anything? If not, you need to check your optical probe.
Electric_John
12:19:42 Initializing serial…
The optical probe is ok, because she read data in map110 on ZMG410
This is an ZMG310
This is what I received:
12:19:42 Initializing serial connection.
12:19:43 Send SNRM request.
7E A0 07 03 01 93 3C 22 7E
12:19:48 Data send failed. Try to resend 1/3
12:19:53 Data send failed. Try to resend 2/3
12:19:58 Failed to receive reply from the device in given time.
12:19:58 Disconnect request
12:19:58 Send Disconnect request.
7E A0 07 03 01 53 30 E4 7E
12:20:03 Data send failed. Try to resend 1/3
12:20:08 Data send failed. Try to resend 2/3
12:20:13 Failed to receive reply from the device in given time.
Hi, You need to change the…
You need to change the interface from HDLC to HdlcWithModeE.
Electric_John
I put HdlcWithModeE and I…
I put HdlcWithModeE and I received same error, can I give you my id and password for anydesk, maybe you can help me to read data...I pay if I succeed! my email is v480007@gmail.com
Hi, I'm sorry, but we can…
I'm sorry, but we can help only our customers with email or Anydesc.
Check the log. Are you receiving any reply from the meter?
Electric_John
same error...and I put a…
same error...and I put a pictures with settings
Hi, Change address type back…
Change address type back to Default and set Physical address to 1.
Uncheck "Use Maximum baud rate".
GXDLMSDirector should send an IEC handshake, but that is not sent. Have you modified the source code?
Electric_John
(Thank you for your fast…
(Thank you for your fast answer) Same error and no, I didn't modified the source code...
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply)
You need to change the authentication level to None.
Electric_John
now I received a new error…
now I received a new error...I don't have port 8 in device manager or program
GXDLMSDirector 9.0.2311.1001
Log created 10:24:57
10:25:06 Initializing serial connection.
System.IO.IOException: The port 'COM8' does not exist.
at GXDLMSDirector.GXDLMSCommunicator.InitSerial()
10:25:49 Initializing serial connection.
10:25:50 IEC Sending:/?!<CR><LF>
10:26:01 Failed to receive reply from the device in given time.
Hi, Make sure that you have…
Make sure that you have the correct driver for the optical probe that you are using.
This looks more and more like an optical probe problem because the L&G E550 should reply to the IEC query.
Electric_John
if the driver is the problem…
if the driver is the problem, why map110 read data from ZMG410C?
because he didn't have transfer connection (like in the picture), but what is direct connection?
Hi, It might be that your…
It might be that your meter is configured and IEC handshake is not used. You can try to find the correct settings using HDLC Address resolver.
https://youtu.be/BeaWKmyMwuE?si=2QI9MbvvfavIp8E4
