  3. Using DLMS LORAWAN Protocal
By akshy , 2 February, 2024
I need to connect meter using LORAWAN protocol I did not find any related articles and details please let me know the kick start how i can connect my meter Using DLMS LORAWAN Protocol..
Below are the requirements
We need to archive a remote AMR capabilities, the prepaid smart meter has a NIC Lorawan modem, that we can use to communicate to it able able to perform the following tasks.
1. Requesting meter energy data's, like Current, voltage, power, remaining balance
2. Able to send the recharge token to the meter via Lorawan gateway using LORAWAN protocol, the meter will be connected to the lorawan gateway only. not a TCP
3. The meter has OBIS codes provided by the manufacturing and its a DLMS support meter.
2 years 9 months ago
Hi, Is your meter supporting…
Is your meter supporting LoRaWAN (LPWAN) or do you want to implement NIC that communicates LoRaWAN to the HES?
akshy
The meter has LORAWAN NIC,…
The meter has LORAWAN NIC, its a swappable communication module. means you can decide to use 4G or whatever. meter is a DLMS.
Hi, DLMS LoRaWAN support has…
DLMS LoRaWAN support has not been implemented yet. It's not in the worksheet and I don't know when it will be implemented.
