By Lotusv , 20 October, 2023 Forums General discussion Is there a Gurux.DLMS package for OpenWRT in the .ipk installation package? If not, how can I install the libraries on OpenWRT myself? Hi, You need to install Java… Hi, You need to install Java or Python for the OpenWRT and then you can use client examples to read your meter. You can also use ANSI C or ANSI C++, but Java and Python are the easier options. BR, Mikko
