  3. UART Gurux
UART Gurux
By Frank G , 20 October, 2023
Gurux.Serial
is there a Python Class to read the meter directly over UART (Not over Serial)?
Similar to the class serial, but direct for UART.
Many Thanks
Frank
3 years ago
Hi Frank. UART is a serial…
Hi Frank.
UART is a serial port. The UART is used with embedded systems when you write bits to a PIN that the microcontroller is using.
