  2. Java Gurux Dlms Server Use For?
Java gurux dlms server use for?
By nikorn , 17 October, 2023
I trying to understand about gurux dlms server java use for waht? Due to I can use gurux dlms client for read Meter dlms via serial port or TCP port success.
Please you explain me about gurux dlms server.
Thank you.
2 years 7 months ago
Hi, Gurux DLMS server…
Gurux DLMS server implements the meter that is used when you want to implement the meter e.g. when simulating the meters.
wenfengzhao
2 years 6 months ago
How to make the Gurux DLMS…
How to make the Gurux DLMS Server actively push information to the set IP port?
