  3. Any Source Code or Example To Use of Dynamic IP Https://www.gurux.fi/Gurux.DLMS.DynamicIP#Java
Any Source code or example to use of Dynamic IP https://www.gurux.fi/Gurux.DLMS.DynamicIP#Java
By mightyChamp , 12 September, 2023
I am trying to build TCP client Server for Dynamic IP GSM Meters in Java. I got below link to work:
but it doesn't have actual source code or example, it would be great if we have example for same.
Thank You
3 years 1 month ago
Hi, You are right. I'll add…
You are right. I'll add that to the work list, but I don't know when it can be released.
