  3. Simulator - Error ServiceError Initiate Error Exception. Initiate IncompatibleConformance
Simulator - error ServiceError Initiate error exception. Initiate IncompatibleConformance
By JavierDiaz , 17 August, 2023
I have xml file and string connect for start simulator:
Gurux.DLMS.Simulator.Net.exe -p 1000 -x sim.xml -t Verbose -N 1 -a None -c 7 -s 1 -l 0.
Simulator meter settings:
Start protocol - DLMS
Authentification - None
ClientAddress - 7
Logical Server - 0
Physical server - 1
Host - localhost
Port - 1000
Log:
DLMS HDLC Logical Name simulator start in ports 1000-1000.
Waiting 1.00:00:00 before next execution.
Server address: 1
Associations:
Client address: 1 HighECDSA authentication, password
Conformance:
ReservedZero, GeneralProtection, GeneralBlockTransfer, Read, Write, ReservedSeven, BlockTransferWithGetOrRead, BlockTransferWithSetOrWrite, SelectiveAccess
MaxReceivePduSize: 1000 MaxSendPduSize: 1000
Security suite: Suite0
Security policy: None
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Broadcast block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Client address: 0 Without authentication.
Conformance:
None
MaxReceivePduSize: 0 MaxSendPduSize: 0
Conformance:
None
When trying to connect to a virtual device, an error occurs:
"ServiceError Initiate error exception. Initiate IncompatibleConformance".
Please tell me what is my mistake.
3 years 2 months ago
Hi, I believe that your…
I believe that your client address is wrong. For some reason, you have two associations where the client address is zero and that is not correct.
JavierDiaz
3 years ago
Thanks, it works!
Thanks, it works!
