  3. Deletion of Existing Data
Deletion of existing data
By kevin jose minj , 19 May, 2023
Is there any way to delete the old data in the DLMS meter? It is showing some junk values
3 years 6 months ago
Hi, You can't remove single…
You can't remove single rows but you can clear the buffer of the meter if you select "Reset" button.
It will clear all data from the profile generic buffer!
