Hello, I am using .NET library. The ReadRowsByRange method generates different bytes depending on where the code is executed. On my local work computer, one result is obtained, and in the docker container on linux (Ubuntu) there are other bytes.
public void ReadValuesByDateRange(DateTime start, DateTime end)
var profileGeneric = new GXDLMSProfileGeneric(LogicalName);
_spodesClient.Read(profileGeneric, 3);
var reply = new GXReplyData();
var dataToSend = _spodesClient.SecureClient.ReadRowsByRange(profileGeneric, start, end);
There are several parameters that affect communication. There is also a sequence counter that is increased with every read, but in your case the start and end dates are different.
Windows is using UTC:
Hi, There are several…
<!-- 25.1.2023 0.00.00Z -->
Docker is using the current time zone (UTC+3:00)
<!-- 25.1.2023 0.00.00+03:00 -->
