I plan on using the load functionality of the GXAssociationLogical name to load the association view from the filesystem as an XML file but the load method takes in a GXXmlReader which I cann spawn an instance of - how can I go about doing so?
You can serialize the objects using GXDLMSObjectCollection.load -method. You need just read the association view and then call GXDLMSObjectCollection.save.
Check the client example. It doesn't what you need when you add -o argument.
-o output.xml
Hi, You can serialize the…
-o output.xml
Thank you for your assistance
