By pavith , 6 January, 2023 Forums Gurux DLMS for Java hi, i have given all the parameters to enable authentication. but simulators not using those( it is starting without authentication) \gurux.dlms.java\gurux.dlms.simulator.java>java -jar target/gurux.dlms.simulator.java-0.0.1-SNAPSHOT.jar -a high -h 192.168.26.2 -p 4059 -T 4954503030373931 -B 32323232323232323232323232323232 -P 1A2B3C4D5E6F7G8H -A 32323232323232323232323232323232 -t Verbose -x crystal.xml DLMS HDLC Logical Name simulator start in ports 4059-4059. Server address: 1 Associations: ++++++++++++++++++++++++++++ Client address: 16 Without authentication. Conformance: [GET] MaxReceivePduSize: 832 MaxSendPduSize: 65535 Hi, Hi, There is only one association in your XML and it's not using authentication. You need to add a new association where authentication is used. That is the easiest if you read the meter with a simulator using authentication. BR, Mikko
