  2. Help Gurux.DLMS.Simulator.Net and Gurux.DLMS.Client.Example.python
By amartinez10 , 24 November, 2022
I'm trying to test the next communication. First, in my PC I have the simulator running, like this:
D:\Gurux.DLMS.Net-master\Gurux.DLMS.Simulator.Net\bin\debug\netcoreapp3.1> .\Gurux.DLMS.Simulator.Net.exe -p 4058 -x crystal.xml -N 1 -X
DLMS HDLC Logical Name simulator start in port 4058 implementing 1 meters.
Waiting 1.00:00:00 before next execution.
Server address: 1
Associations:
Client address: 16 Without authentication.
Conformance:
Get
MaxReceivePduSize: 832 MaxSendPduSize: 65535
And I want to communicate with my PC throught an IIOT, with Python, but I can't:
python main.py -h 192.168.10.169 -p 4058
gurux_dlms version: 1.0.137
gurux_net version: 1.0.20
gurux_serial version: 1.0.20
ClientAddress: 0x10
Standard: Standard.DLMS
Access Error : Unknown error.
I am very begineer with this, can somebody help me?
Thanks in advance
3 years 8 months ago
Check your host address. You can also add -t argument to get a trace.
-t Verbose
amartinez10
Hello Mikko, thanks for your
Hello Mikko, thanks for your answer.
This happens now:
root@iot2050-est02-ct1:/home/andres/Gurux# python main.py -h 192.168.10.169 -p 4058 -t Verbose
gurux_net version: 1.0.19
ClientAddress: 0x10
TX: 10:31:52 7E A0 07 03 21 93 0F 01 7E
RX: 10:31:52 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 10:31:52 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
RX: 10:31:52 7E A0 07 21 03 97 2B E1 7E
TX: 10:31:52 7E A0 07 03 21 53 03 C7 7E
RX: 10:31:52 7E A0 1E 21 03 73 C3 7A 81 80 FD 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 CF 99 7E
Greetings
I notest that Github version was not the same as in the internal repo. Get the latest version and let me know if you still have problems.
amartinez10
Hello Mikko,
Hello Mikko,
I still have problems:
root@iot2050-est02-ct1:/home/andres/Gurux# python main.py -h 192.168.10.169 -p 4 058 -t Verbose
ClientAddress: 0x10
TX: 09:50:39 7E A0 07 03 21 93 0F 01 7E
RX: 09:50:39 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 0 0 01 08 04 00 00 00 01 53 3B 7E
TX: 09:50:39 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 0 8 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
RX: 09:50:39 7E A0 07 21 03 97 2B E1 7E
TX: 09:50:39 7E A0 07 03 21 53 03 C7 7E
RX: 09:50:39 7E A0 1E 21 03 73 C3 7A 81 80 FD 05 01 80 06 01 80 07 04 00 00 0 0 01 08 04 00 00 00 01 CF 99 7E
Have you modified the source code? I got the latest version from GitHub and it worked without problems using your parameters.
amartinez10
No, I didn't. Can be
No, I didn't. Can be something related with my pc configuration, like firewall?
No. You can establish the connection for the meter, but then something happens and the connection is closed. The reason is at the simulator. Try to get the latest version from Github to a different directory. Compile it and try again.
amartinez10
Mikko,
Mikko,
the same, nothing changes.
Greetings
3 years 7 months ago
It seems like your simulator is in Windows and Python client is on Linux.
What Linux distro you are using?
amartinez10
I'm using Linux 5.10
Greetings
HI,
HI,
Is the distro Debian, Ubuntu, etc? I'm asking so this can be tested with the same environment.
amartinez10
Debian Greetings
Debian
Greetings
  • IUJbutxeSTSNcNRN
  • Peraturaidetetug
  • NnmIomcqcTDVWiDuCD
  • iRnseovnShdVWR…
  • HgGuaAJJjTLjzz…
