By ykhristo , 6 November, 2022 Forums Gurux.DLMS Greetings, I was wondering if the C++ version of GuruX supports ECDSA authentication, and if not whether this support will be coming to this version. Thank you and best regards Hi, Hi, ANSI C++ doesn't support ECDSA at the moment. Support for ECDSA is added at some point, but I don't have the schedule for that at the moment. I can say for sure that it's the earliest in next year. BR, Mikko Greetings Mikko, Greetings Mikko, very well then, thank you for your prompt response. Best regards Hello, If you are still… Hello, If you are still interested in ECDSA, ECDSA authentication was added to the ANSI C++. BR, Mikko
Greetings Mikko,
Greetings Mikko,
Best regards
