  3. GXDLMSLimiter MonitoredValue Does Not Bind
GXDLMSLimiter MonitoredValue does not bind
By ali_bahal , 10 August, 2022
hi, when I'm reading GXDLMSLimiter object, it's MonitoredValue attribute does not bind and returns null.
I checked packets and it contains data correctly.
7E A0 1C 00 02 76 71 03 32 98 1F E6 E6 00 C0 01 C1 00 47 00 00 11 00 00 FF 02 00 9B 28 7E
7E A0 22 03 00 02 76 71 52 D8 51 E6 E7 00 C4 01 C1 00 02 03 12 00 03 09 06 01 00 16 07 00 FF 0F 02 87 51 7E
3 years 11 months ago
Check that register object 1.0.22.7.0.255 is in the association view. The monitored value is not shown if the object is not in the association view. This is changed for the next version and the monitored value is shown even if it's not in the association view.
ali_bahal
Thank you. the problem was
Thank you. the problem was this. I handled error by adding this object manually to association view
You don't need to add that manually anymore. Update to the latest version and it can handle if the monitored value is not in the association view.
  • Aij
  • vondamc1
  • JosephNok
  • IUJbutxeSTSNcNRN
  • Peraturaidetetug
