Hello. I am developing a function in .NET for an Iskra MT880 meter. I have already initialized the communication with the meter and I would like to know how to obtain the data of load profile 1. Currently I have the code like this but it throws an error: "Capture objects not read"
I'm new to DLMS/COSEM and I can't understand it very well. I appreciate your help in solving the problem.
*** already solved ***
After declaring the variable "it" put "reader.Read(it, 3)". After store in a variable "object[]" which returns the function "ReadRowsByRange" to see the data.
I'm glad that you solved this. I'll add the answer here anyway.
You need to read capture objects before you can read the buffer.
