  3. Which Source Is The Last Version?
Which Source is the last version?
By AliDev7 , 24 July, 2022
Gurux.Net
I'm try to create Client and server AMR from your Library (.Net). there are multiple source codes and document that I see in your website and in github repository. I wonder which on is the last version?
Because I have problem to implement sample codes. like this :
// Step 2: Initiate the Image transfer process.
ReadDataBlock(Client, Media, target.ImageTransferInitiate(Client, Identification, data.Length), reply);
'ReadDataBlock' function has two input, but in your code, you pass 4 input parameters to this function.
I appreciate if you help me with this :)
4 years 4 months ago
You can use DLMS Client example to read your meter and modify it for your needs.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E…
