  3. WriteList
WriteList
By ali_bahal , 7 June, 2022
Hi, I wanted to know is it possible for you to add method for block set (writing list of attribute in a block)
for meters who support "BlockTransferWithSetOrWrite".
if not, do you have any hint for me? (any help appreciated)
ali_bahal
4 years 1 month ago
sorry I found this method :
public byte[][] WriteList(List<KeyValuePair<GXDLMSObject, int>> list)
in your library . only I want to know is this method usage like ReadList in gxDlmsDirector or there is anything that should be changed?
4 years 1 month ago
You use it in the same way as the ReadList. Just set the values that you want to write for the objects and write.
ali_bahal
4 years 1 month ago
thank you I'll check it and
thank you I'll check it and let you know
  • Georgegeowl
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
