  3. Code 283 When Reading The Counter
Code 283 when reading the counter
By Ingvar , 3 June, 2022
I can't read the parameters from the meter. The time reads correctly, but when trying to read L1 phase voltage (1.0.32.7.0.255) get error 283.
As I understand it is a mistake DLMS_ERROR_CODE_INVALID_INVOKE_ID
At the same time DLMS Director reads normally with the same settings? What could be the problem?
The logs are on the link:
https://drive.google.com/file/d/1d82XXpID7daoVQqKChGXpb_cPGXVOfsM/view?…
Ingvar
4 years 2 months ago
I looked at the frame through
I looked at the frame through the Dlms Translator, it turned out that the type of object - Extended Register, instead of Register.
I apologize for the inconvenience. I think you can delete the topic.
  • Georgegeowl
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
