  3. Obtain Obis Values In Raw
Obtain obis values in raw
By zon7 , 2 June, 2022
I have an object I need to read but the device is wrongly reporting that capture object is empty (I know it's an structure) and I can see Gurux has obtained it, but as I don't have the capture object it cannot parse it.
I'm using the python GXDLMSReader example. It's possible for the read method to return the raw array structure without throwing an error?
4 years 2 months ago
If you know what objects are in the capture object list you can add them manually.
Something like
pg = GXDLMSProfileGeneric("LOGICAL NAME")
pg.captureobjects((GXDSLMSClock(), GXDLMSCaptureObject(2, 0)))
//Add other captured objects....
read(pg, 2)
  • Georgegeowl
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
