  2. Something Weird In Notification Body
Something weird in notification body
By wooreeinfo , 25 May, 2022
I sent notification through sendPush() method on server example.
It works perfectly, but it seems to be weird when Profilegeneric object included.
It couldn't be translated with Gurux DLMS Translator on GXDLMSDirector.
It shows like this :
BlockCipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Authentication Key:D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
1: 7E A0 85 81 01 13 78 0B E6 E7 00 0F C0 00 00 01 00 01 00 00 00 01 6D 02 04 01 04 02 04 12 00 28 09 06 00 07 19 09 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 2A 00 00 FF 0F 02 12 00 00 02 04 12 00 2A 09 06 00 00 19 01 00 FF 0F 03 12 00 00 02 04 12 00 07 09 06 01 00 63 01 00 FF 0F 02 12 00 01 09 03 12 34 56 06 C0 A8 00 21 01 01 02 02 09 0C 07 E5 04 03 06 12 00 00 FF FD E4 00 05 00 00 00 02 21 06 7E
<HDLC len="84" >
<TargetAddress Value="40" />
<SourceAddress Value="0" />
<!-- Notification frame. -->
<FrameType Value="13" />
<PDU>
<DataNotification>
<!-- High priority. -->
<!-- Confirmed service. -->
<!-- Invoke ID: 1 -->
<LongInvokeIdAndPriority Value="C0000001" />
<!-- 0001-01-01 오전 12:00:00 -->
<DateTime Value="" />
<NotificationBody>
<DataValue>
<Array Qty="00" >
</Array>
</DataValue>
</NotificationBody>
</DataNotification>
</PDU>
</HDLC>
I added two lines at addPushSetup() method in server example like this :
GXDLMSProfileGeneric pg = (GXDLMSProfileGeneric) getItems().findByLN(ObjectType.PROFILE_GENERIC, "1.0.99.1.0.255");
push.getPushObjectList().add(new GXSimpleEntry<GXDLMSObject, GXDLMSCaptureObject>(pg, new GXDLMSCaptureObject(2, 0)));
Then I called sendPush() method on main() method like this :
GXDLMSProfileGeneric pg = (GXDLMSProfileGeneric) LNServer.getItems().findByLN(ObjectType.PROFILE_GENERIC, "1.0.99.1.0.255");
LNServer.getProfileGenericDataByEntry(pg, 1, 1); // get a row for test
GXDLMSPushSetup push = (GXDLMSPushSetup) LNServer.getItems().findByLN(ObjectType.PUSH_SETUP, "0.7.25.9.0.255");
LNServer.sendPush(push);
If commented getProfileGenericDataByEntry method, then it works perfectly.
It looks like something weird.
Please let me know if I had something wrong.
Thanks in advance.
Hyunse Cho
wooreeinfo
4 years 2 months ago
It might be that I found something. I'll get back to this after I have verified this.
I create an issue from this and it's now fixed.
http://www.gurux.fi/node/19929
Get the latest version.
wooreeinfo
Thank you for the information
Thank you for the information.
It works perfectly.
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
