By sushant5252 , 24 March, 2022 Forums General discussion is there any idea how we can parse the Received frame from Secure Meter premier 300 model, i want to get V,I,KWH etc parameter using python . i am able to make connection with meter and received data on DLMSDirector. Hi, Hi, You can use client example to read data from the meter. https://github.com/Gurux/Gurux.DLMS.Python/tree/master/Gurux.DLMS.Clien… Use the command line settings that are shown in GXDLMSDirector when you select the meter. BR, Mikko
