  2. DLMS With Arduino IDE
DLMS with Arduino IDE
By ichsan05 , 22 March, 2022
I have question regarding the DLMS.c master for Arduino IDE
1. Is there any documentation for the code what to be and not to be defined in the code or there's a setting to use serial port RS-232 because i need to connect my MCU to The smart meter using RS-232
2. Is it safe to directly connect MCU to RX TX GND of smart meter?
Thank you in advance.
4 years 4 months ago
1. You can start from here: https://www.gurux.fi/Arduino
The Arduino example is already using RS-232.
2. You need to check that your UART power levels are the same on the MCU and the meter.
ichsan05
Thank you so much for the
Thank you so much for the reply i will immediately try it
Ichsan
  • BaEdhlfwwvUqFMkOYk
  • CrzONrPdvkWUif…
  • kra4026
  • HilipLot
  • NithnCXPiBJHVG…
