Try to connect with the Client example. Add system title (-T), block cipher (-B), and authentication keys (-A) as a command-line parameter. You also usually need to read the Invocation counter using -v parameter.
Yes, our clients are reading Italy Standard UNI/TS 11291-11-2 meters. Are you using a concentrator or do you have a direct TCP/IP connection for the meter?
I can see from your settings, that you want to establish a Management connection.
Can you establish the connection with GXDLMSDirector first? It's easier to verify your parameters.
You need to read Invocation counter using -v 0.1.43.1.1.255 if your meter connection is Off-line and 0.0.43.1.1.255 if your meter connection is On-Line.
Try to establish the connection without authentication (Public) first.
Our meter has direct TCP/IP connection and our software most be server , meter is connect to our software.
I read meter with public , its OK and no problem.
I read invocation counter and set to client.ciphering.invocation
But when i try to read with HLS + HighGmac , meter didn't response to my AARQ.
There are differences between the meter manufacturers in how they behave in auto-connect mode (Meter connects for the server).
Try not to call Release. That works for some meters. Some meters expect that the release is called after you have read the IV and some meters can't handle any commands after you call release.
I tried but meter didn't
I tried but meter didn't response.
How Can i creat AARQ with Glo-cipher for Italy standard with gurux .net library?
It's possible?
thanks for your response.
