  3. Gurux.DLMS.AMI Setup In Linux Environment
Gurux.DLMS.AMI setup in Linux environment
By aeeccims@tnebnet.org , 8 October, 2021
Gurux.DLMS.AMI
I am new to DLMS subject and in the process of development of MDAS for the organisation.
We have only linux environment for server and need to set up in linux environment only.
Is it possible to set up in Linux If so any guidance is appreciated.
Thank you in advance
4 years 11 months ago
1. You need to install dotnet for the linux.
2. Then build the Gurux.DLMS.AMI
dotnet buid Gurux.DLMS.AMI.sln
3. Start the Gurux.DLMS.AMI.
dotnet Gurux.DLMS.AMI.dll
Hi Mikko
Hi Mikko
Thank you so much for fast response.
I try and get back in case any further clarifications.
Thank you once again.
