  3. Firmware Update : Unavailable Object Error Response
By Bhaumik , 16 August, 2021
I am trying to update firmware into IS15992 standard meter.
In firmware update, all blocks (Total 625 blocks) were transmitted successfully.
After completion checked for all block transferred status. In that getting 589 were successfully updated out of 624 blocks.
Again started firmware update and it starts from 589 and again all blocks were updated successfully.
Then checked for all block transferred status and again got 589 from the meter.
I have checked from DLMS translator and in that show "<Result Value="UnavailableObject" />" error.
BlockCipher key: 30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46
Authentication Key:30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46
1: 00 01 00 01 00 50 00 18 CF 16 30 00 02 F5 0B 09 33 2E 08 5A 30 F4 AB BF BF 08 18 FF C8 E5 EB F6
<WRAPPER len="20" >
<TargetAddress Value="1" />
<SourceAddress Value="50" />
<PDU>
<!-- Invocation Counter: 193803 -->
<!-- Decrypt data: C7 01 C1 0B 00
<ActionResponse>
<ActionResponseNormal>
# Priority: High, ServiceClass: Confirmed, Invoke ID: 1
</ActionResponseNormal>
</ActionResponse>
<glo_ActionResponse Value="300002F50B09332E085A30F4ABBFBF0818FFC8E5EBF6" />
</PDU>
</WRAPPER>
Please find attached a screenshot for the same.
Can you please check and provide your suggestion?
5 years 1 month ago
There is something wrong with the meter. Is image verification or activation causing this error?
You should ask the meter vendor if there is a fix for this.
Bhaumik
5 years 1 month ago
This happened during the firmware update process only. In an ongoing process, suddenly got this type of response. And for the rest of all blocks getting the same error response.
Image verification and activation method were not executed. So it is not causing this error.
Let me confirm with the meter vendor also.
