  3. How To Get All Supported Obis Code List
How to get all supported obis code list
By mightyChamp , 31 July, 2021
I want to get all supported obis code list from meter. When I use Director Software, On first connect it automatically add many obis code in it.
Is all obis are here which is supported by meter, or meter may have other than these obis codes?
Thank You
5 years ago
Each meter is different and the amount of supported OBIS codes vary between the meters. The meter can give all supported objects when the association view is read. GXDLMSDirector does this automatically on the first connection.
So you need to read the association view to get information from supported OBIS codes. Because reading is taking a long time it's usually a good idea to save association view.
  • liha_2019
  • FiqJXzPfbTtORWoZ
  • Georgegeowl
  • brsRKNujhfnXWm…
