  2. Com_read Returns Invalid Parameter
com_read returns Invalid Parameter
By Mohanraj , 27 July, 2021
Hope you are doing good. We are observing strange problem in com_read function. At times com_read returns error code DLMS_ERROR_CODE_INVALID_PARAMETER i.e in decimal 258. I remember this problem was resolved in stack(https://www.gurux.fi/node/16144) and we are using the latest ANSCI C library only. could you please tell us what is the problem?
Below is the code snippet
read_data()
cosem_init()
com_read(&con, profile_obj, 3);
com_read(&con, profile_obj, 2);
Below is the trace of TX and RX.
TX : 7E A0 19 03 41 BA 7A B5 E6 E6 00 C0 01 81 00 07 01 00 5E 5B 00 FF 03 00 4C 96 7E
RX : 7E A8 89 41 03 DA 8B A4 E6 E7 00 C4 01 81 00 01 16 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0C 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0B 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5B 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0D 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0E 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 07 25 5C 7E
TX : 7E A0 07 03 41 D1 4C 05 7E
RX : 7E A8 89 41 03 DC BD C1 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 05 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 8C FE 7E
TX : 7E A0 07 03 41 F1 4E 24 7E
RX : 7E A8 89 41 03 DE AF E2 0F 05 12 00 00 02 04 12 00 03 09 06 00 00 5E 5B 0E FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 00 01 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 02 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 02 12 00 00 02 04 12 00 46 09 06 00 00 60 03 0A FF 0F 02 93 3D 7E
TX : 7E A0 07 03 41 11 40 C3 7E
RX : 7E A0 1E 41 03 D0 1F E8 12 00 00 02 04 12 00 47 09 06 00 00 11 00 00 FF 0F 03 12 00 00 52 B5 7E
TX : 7E A0 19 03 41 D6 10 1C E6 E6 00 C0 01 81 00 07 01 00 5E 5B 00 FF 03 00 4C 96 7E
RX : 7E A8 89 41 03 9C B9 83 E6 E7 00 C4 01 81 00 01 16 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0C 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0B 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5B 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0D 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0E 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 07 25 5C 7E
RX : 7E A8 89 41 03 9E AB A0 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 01 06 00 FF 0F 05 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 00 09 06 00 FF 8C FE 7E
RX : 7E A8 89 41 03 90 D5 49 0F 05 12 00 00 02 04 12 00 03 09 06 00 00 5E 5B 0E FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 00 01 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 02 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 02 12 00 00 02 04 12 00 46 09 06 00 00 60 03 0A FF 0F 02 93 3D 7E
TX : 7E A0 07 03 41 31 42 E2 7E
RX : 7E A0 1E 41 03 92 09 89 12 00 00 02 04 12 00 47 09 06 00 00 11 00 00 FF 0F 03 12 00 00 52 B5 7E
Mohanraj
5 years ago
Hi Mohanraj,
Hi Mohanraj,
What method returns this error?
Mohanraj
5 years ago
In reply to Hi Mohanraj, by Kurumi
HiMikko,
HiMikko,
we are not able to go in details. but the return value of com_read is DLMS_ERROR_CODE_INVALID_PARAMETER. further any com_read returns the same error code.
Mohanraj
Mohanraj
5 years ago
Incase if stack returns DLMS_ERROR_CODE_INVALID_PARAMETER for com_read function how to recover it? please suggest workaround? and why stack should return that error code when data is correct?
Mohanraj
5 years ago
In your trace above you read attribute index #3 twice. Check why this is happening.
Mohanraj
5 years ago
for every time we are reading index #3 followed by index #2. is not recommended?
what do you suggest?
read index #3 once for profile generic object after that continuously we can read only index#2?
Mohanraj
4 years 12 months ago
Hi Mohanraj,
Hi Mohanraj,
You need to read capture objects before you read index #3, but in your trace, you have read index #3 twice and not read index #2 at all. Check your code. I believe that you have made medications for com_read -method.
Mohanraj
how to read capture objects before reading index#3 followed by index#2?
I assume that com_read(&con, profile_obj, 3) is reading capture object and com_read(&con, profile_obj, 2) is data
please correct and suggest.
Mohanraj
Hi Mohanraj,
Hi Mohanraj,
You are right. I suggest that you check that you haven't modified the source code. I believe that is the problem why you are reading capture objects twice or then your trace above is wrong.
Mohanraj
i have not modified the source. it was a mistake that we were referring wrong trace.
Mohanraj
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
