  3. Time Synchronization Possibility
Time synchronization possibility
By DenisMalakhov , 28 June, 2021
Hello, is it possible to make synchronization mechanism like this https://en.wikipedia.org/wiki/Network_Time_Protocol#Clock_synchronizati…?
5 years 4 months ago
You should check If the meter is supporting NTP setup.
DenisMalakhov
Unfortunately, it is not
Unfortunately, it is not supported. So I would like to know if there is a way to perform proper time synchronization without an NTP configuration object?
The only way to do this is to establish the connection to the meter and then set the time using the Clock object.
