  3. Wrong Certificate Serial Number Received From Gurux Remove The Certificaet
Wrong certificate serial number received from gurux remove the certificaet
By aoudumbarpawar , 24 June, 2021
Hii Sir,
With the updated gurux i am not able to remove any certificate from the meter.
while testing i found that the gurux sending wrong serial number (inverse direction) of the certificate for remove certificate method.
E.g:
Actual Serial Number of the certificate
Decimal = > 1001562
Hex = > 0x0f 48 5a
03 0f 48 5a == > for export certificate => gurux certificate number received from gurux by serial number
03 5a 48 0f == > for remove certificate => remove gurux root certificate serial number received from gurux by serial number
AP
4 years 11 months ago
If you add a new certificate it should override the old one.
aoudumbarpawar
Hii,
Hii,
Yes override it. problem is that for same certificate Export certificate received correct serial number from gurux (MSB-LSB) but for remove certificate request received wrong certificate serial number from gurux.
AP
aoudumbarpawar
Hii,
Hii,
Below is the request log details for the export certificate method and remove certificate method.
------------------------------ Log of export certificate ------------------------------------------------------------------
TX:7E A0 5A 00 02 BA 69 61 54 3C 3F E6 E6 00 C3 01 C1 00 40 00 00 2B 00 01 FF 07 01 02 02 16 01 02 02 09 03 0F 48 5A 09 31 43 4E 3D 52 6F 6F
74 20 43 41 20 32 35 36 2C 20 4F 3D 47 75 72 75 78 20 53 65 63 75 72 69 74 79 2C 20 4C 3D 54 61 6D 70 65 72 65 2C 20 43 3D 46 49 C8 B1 7E
Serial Number in request:
0F 48 5A
---------------------------- Log of remove certificate -------------------------------------------
TX:7E A0 5A 00 02 BA 69 61 54 3C 3F E6 E6 00 C3 01 C1 00 40 00 00 2B 00 01 FF 08 01 02 02 16 01 02 02 09 03 5A 48 0F 09 31 43 4E 3D 52 6F 6F
74 20 43 41 20 32 35 36 2C 20 4F 3D 47 75 72 75 78 20 53 65 63 75 72 69 74 79 2C 20 4C 3D 54 61 6D 70 65 72 65 2C 20 43 3D 46 49 AA 7F 7E
5A 48 0F
AP
You are right. Thank you for pointing this out. I created an issue from this.
http://gurux.fi/node/18676
This is fixed for the next release.
