  3. Gurux Shows Certificates Serial Numbers In Negative
Gurux shows certificates serial numbers in negative
By aoudumbarpawar , 24 June, 2021
Hii,
With updated gurux, when i read the certificates info gurux shows certificates serial numbers in negative.
Snap is attached.
AP
5 years 5 months ago
Thank you for pointing this out.
This is already fixed. When you generate the next certificate the serial number is correct.
