  2. Ignore Packets With Different Source and Target
ignore packets with different source and target
By ali_bahal , 22 June, 2021
I have a meter that I use it's gprs modem to read data. but when I read parameters , it send some Irrelevant packets with different source and target address. is there a way to ignore this packets ?
in below example, last packet is of this kind.
Send AARQ request.
TX: 00010001000100386036A1090607608574050801018A0207808B0760857405080201AC0A80083030303030303030BE10040E01000000065F1F0400001E5DFFFF
RX: 00010001000100446142A109060760857405080101A203020100A305A10302010088020780890760857405080201AA0A80083030303030303030BE10040E0800065F1F040000101801000007
Read object type Register index: 3
TX: 000100010001000DC001C100030100200700FF0300
RX: 000100010001000AC401010002020F001623
Read object type Register index: 2
TX: 000100010001000DC001C100030100200700FF0200
RX: 0001000100010007C4010100120000
TX: 000100010001000DC001C100030100340700FF0300
TX: 000100010001000DC001C100030100340700FF0200
TX: 000100010001000DC001C100030100480700FF0300
TX: 000100010001000DC001C100030100480700FF0200
RX: 0001000100010007C40101001200D2
TX: 000100010001000DC001C1000301001F0700FF0300
RX: 000100010001000AC401010002020FFE1621
TX: 000100010001000DC001C1000301001F0700FF0200
TX: 000100010001000DC001C100030100330700FF0300
TX: 000100010001000DC001C100030100330700FF0200
RX: 0001000100100015DD100000000030333939333330303036313612001F
5 years 1 month ago
That is done automatically. If the source and target address are different than what the client is using data is skipped. This is happening all the time when there are several meters in the RS-485 bus.
ali_bahal
5 years 1 month ago
But why I receive the last
But why I receive the last packet?
5 years 1 month ago
It's shown on the trace, but GXDLMSClient.GetData should skip it. What programming language you are using? I can verify it.
ali_bahal
5 years 1 month ago
We are using c#. It does not
We are using c#. It does not ignore and after that packet I get this error :
Insufficient memory to continue the execution of the program
5 years 1 month ago
I'll test this right away.
ali_bahal
5 years 1 month ago
Thank you. Please consider
Thank you. Please consider the error I get after.
5 years 1 month ago
I checked this and it works like expected. Received data is handled. The problem is that the meter sends invalid data. The message is broken and it's causing the problem.
You should inform the meter manufacturer of this.
I'll talk should messages like this just ignored so they don't break the communication.
ali_bahal
5 years 1 month ago
Thank you very much. I'll
Thank you very much. I'll inform the manufacturer.
ali_bahal
5 years 1 month ago
I talked with meter
I talked with meter manufacturer and they say, It's a keep a live packet and can be recognized with "DD". Despite the matter that keep alive should not be send middle of reading, do you think it's dlms standard?
5 years 1 month ago
I'm sorry to say, but 0xDD is not keep-alive. It's GeneralCiphering where data is encrypted. This is defined in the DLMS standard.
ali_bahal
5 years 1 month ago
  • Brandondiz
  • JeffreyPal
  • DingfanXue
  • UrukTroge
  • Quarryboss
